I've sanded down my Berzerk and don't recall if just the sides had texture, or if the front, monitor shroud area, etc had texture. I think just the sides but if someone with a Berzerk could chime in, I'd appreciate it.
Actually if you use a 'smooth surface' foam roller, it works really well for a textured surface, surprisingly enouph. If you decide to use that, do multiple coats.
Might be the one situation where I'd use a roller to put on the primer. Spray color coats and don't sand between coats, in order to retain the lumpiness.
