Berzerk CP - Does it have a wood backing?
well, that's good to know!
Anyone have a pic of the underside of theirs?
I am trying to install the original bat handle joystick on this (has wood backing) and it seems the shaft is too short...
I want to see if it was recessed in any way with the long joystick plate.
Or, if I am doing something wrong.
Any help is appreciated!
Pics For You...
I hope this helps......original opto-bat......untouched from factory....
(waving hand, using Jedi Mind trick)
"That Joystick doesn't belong to you, you must give it to me immediately"
Yes, thanks! How thick is the wood?
Is there a gap on the top of the CP? So the metal ring is or is not touching the CP?
Well, here's the issue.
I have wood backing on this panel, looks to be original.
It had on a wico stick when I got it. Picked up the bat handle.
I goto mount the bat handle joy to the CP, holes match up.
Once I try putting the handle through the joystick base, it seems too short.
First thing that comes to my mind is that the wood is too thick. This wouldn't make sense though if this joy was supposed to be on the machine.
Do you thing shaving the wood around it to countersink it?
Is the joy built correctly? I looked at the schems and it seems so...
Why such a difficult install?
Doesn't look like that in the OP pics...
It seems to be about a 1/2" too short.
I can put the metal disc (that is used for the optics) on but cannot attach the bolt.
More..
Wood is 3/4" thick...metal washer sits approximately 1/8" below the CP (gap).
I could measure more but for some strange reason I just boxed up my entire control panel and shipped it FED-EX to Talon2000....;)
