Berzerk after moving isnt happy with me.
parabolic
Greer, South Carolina
Well, as far as everything making the move, I thought I had little to no casualties. Well tonight I decided to start unwrapping games and firing them up. The FIRST one I tried - Berzerk - was apparently hurt during the move. I only get 6 beeps and then nothing. According to the book its somewhere in the vfb board. I did a search and didn't find anything listed for 6 beeps/flashes. Of course it was working fine before the 700 mile move.
any ideas?
uhhh, i have no ideas. let me check my trusty crystal balls.
my guess is something gotsed disconnected. try taking off the back door and see if anything obvious is hanging loose.
if all is well then you need to see if boards are getting the proper voltages. a schematic would tell you what where but not how.
heres a manual.
http://www.crazykong.com/manuals/Berzerk.man.pdf
yah....
been all over that already. was looking for someone who could ID the beeps/flashes for a board diag.
thanks for the attempt though
The manual just lists some chips to check on the vfb board. If my memory is correct (probably not) these are not socketed chips. I would put my money on one or more of the interconnect cables between boards being loose. Pull those off and reconnect them. Also, check the voltage on the boards at the test points.
If it was the RAM on the VFB board, it would have stopped at the 3rd beep/flash.
