roothorick
Just a quick note for anyone working on one of these -- the cabinet wiring diagram in the manual (page 20) is WRONG. The ticket bin floor switch isn't connected to the doors at all and instead wired directly to the tower light middle. Also, the door pinouts are a bit off.
The correct door connector pinout:
Pin 1 - Compressor motor enable (to test your compressor, short this to ground)
Pin 2 - DC ground
Pin 3 - DC +5V
Pin 4 - DC +24V (door switch disconnects this when the door is opened)
Pin 5 - DC ground
Pin 6 - Tower light top (if a door detects a problem with its ticket eater, it will short this pin to ground)
Pin 7 - Tower light middle (NC on doors 2-4, Door 1 will blink this on and off if pins 6 & 8 aren't @ ground)
Pin 8 - Tower light bottom (if a door detects a problem with its printer, it will short this pin to ground)
Pin 9 - Earth/safety ground
Pin 10 - DC +12V
Pin 11 - DC ground
Pin 12 - DC +12V
Pin 2 - DC ground
Pin 3 - DC +5V
Pin 5 - DC ground
Pin 10 - DC +12V
Pin 11 - DC ground
Pin 12 - DC +12V
