Benching PP - Test harness needed for Pole Position interconnect board?
I need to bench some pole position boards to work on. The two board set makes it really hard to do that and have them up and running. My idea is to have only one board on the bench at a time but I still need them plugged into each other.
What can I make a test harness out of for the interconnect board?
I know that these boards use 30/60 edge connectors also a
ISA 31/62 edge connector might work.
I am thinking a 3ft to 5ft test harness should be just about right.
What kind of edge connectors should I look for?
30/60 Solder Eyelet Connectors
30/60 PC Mount Connectors
Also is this a straight through pass between the two boards?
Any other ideas?
Any other ideas?
