BC-25 change machine no +40v
Petekazel
Troy, Michigan
So I have this rowe BC-25 recently started giving me trouble. The main computer does not light up and I don't have the 40v LED lit up on the power supply card. Needless to say it won't make change or dispense any quarters if I manually press the test switches. I've checked for cold solder joints on the main computer as well as the power supply board. Cannot find anything visually wrong with either board itself. Can anyone offer any assistance?
Won't get 40 volt led until computer sends signal to that relay. Is the board pushed all the way in? There should be a red dot on the on the 7 segment display indicate 5 volt on the board. Do you have the plastic case for the board?
