BBH2 dips and info??
Quazimoto
Long Island::NY
Just swapped out my Golden Tee to a Big Buck Hunter 2 board and can't get to the menu or coin it up. The board looks exactly like a GT board and was wondering if the info from the manual is the same. I have the GT manual but dont have the BBH2 manual. The info on the GT site is only for the most current BBH. Or does anybody have the manual in PDF form that can supply me with the link.
K
Isn't it a standard JAMMA connector on the board? if so, check that the service or test pads are connected to your service or test buttons. if not, then jumper one to ground. That should get you in the menu.
Otherwise, just call IT directly and talk to their support dept....
I jumped the test pin and most of the outputs and they all worked. Just does not want to work through the harness.....I'm thinking it may be a ground somewhere. I dont know why that would be because all buttons and controls work for my GT complete.
