wantdataeast
Bringing a Battlezone back to life, was up to the point where all was good but I had some jittery obstacles, primarily the triangles; and I was having reset issues. Was also having some jittery graphics on the high score screen around center high score. I pulled the boards and used Deoxit spray to clean all the IC legs and sockets (a brass Dremel to burnish. The IC legs), did the same thing on the innerconnect cable between the PCB and the auxiliary PCB board. When I began retesting the jittery obstacle situation seemed to be taken care of, however, after a minute or so of play I got my reset issue back and now have some odd lines that are permanent on the screen during the attraction mode. I can't seem to start a game right now either; but I have still have the start up screen. Now when I go to test menu. I'm seeing a L looking graphic on the right hand side which I've circled in red. The odd Lines do not appear during the test mode as you can see.
