battlezone sound went very low
sconfu
Illinois
so i accidentally left my battlezone on for right at about 30 hours, and now the sound is very low, you have to put your ear against the speaker and you can hear it, the ar/2 hasnt been rebuilt,
so im guessing the sound amp pooped the bed?
is there a specific part that I should look to be blown?
those boards are so easy to rebuild, you ought to do the whole board then see what happens.
www.therealbobroberts.net sells the kits
The AR-2 rebuild kit does not include the TDA-2002 ( there are 2 of them but chances are only one went bad) . Check all voltages too BEFORE placing an order and make sure they are good. The TDA-2002 is the audio amplifier. If your voltages are not good then order the pot and lm305 for the board too. They are not in the kit.
