Battlezone screen fading out FIXED
Brick Top
Portland, Oregon
Just wanted to post this in case it helps someone in the future.
Had a BZ caberet that would fade to black at times. When the monitor quit working I popped off the back door and noticed the heater was out too.
Checked for 6VAC at the brick, fine, continuity of harness, fine, unplugged power harness from deflection board, plugged back in and monitor relit.
Problem was cold solder on power header pins on deflection board. Reflowed solder to back of pins. Fixed.
