Battlezone power help
hot00frb
latham, New York
I have a battlezone I'm working on and the monitor won't power up more then a dot in the center after doing some searching to make sure power is good etc I noticed on the power supply at bottom of cab where the fuses are there's two middle fuses with red wires that are suppsed to be 36 volts and it's only 16 any ideas ???
