busterbear51
Greeting all this is my second post about this machine. The newbie thats getting frustrated !!!
It was working fine and then moved to different location and now she doesnt work.
The symptoms are as follows :
The marque light blinks -?
The machine will start up and then shut it self off and then back on guess you could say its resetting somehow. Then I would get a diagnal line across the monitor. When its resets it sounds like there is a click noise from inside the cab. I also noticed that there is a red light on the monitor board that goes out when it resets. I disconnected the monitor to see if it would play blind but it still continued to reset.
On earlier advice I rebuilt big blue, replaced the power cord and changed the AR2. All fuses checks and appeared fine
Anyone else have any ideas ?
