Battlezone cardboard monitor bezel picture?
Talon2000
Princeton, Texas
I've got what's left of a monitor bezel that was inside the BZ I just got. But after taping it back together to use as a template, I'm not even sure it goes to BZ. Anyone happen to have a picture handy of one installed?
Is yours a cabaret? I can take a pic of mine for you. I'm unfamiliar with uprights; I don't even know if they have a cardboard bezel....
Here is the BZ cardboard backdrop
Its from a upright, with the front bezel scope
Or did you mean the black piece that lays on the monitor?
Your in luck, I assembled my cabinet and forget to put this piece back in. So I have
to photograph. Now I need to get back in the cab......
Mine was in bad shape, but I cleaned it and taped it back together.
Ok so what I have is definitely wrong.. That looks like a flat piece correct. That should be easy enough to reproduce..
Basically you want a piece that covers up all the area around the monitor. Your color filters are taped directly to the monitor and then the black bezel around the monitor.
I made a discovery tonight, while putting the black cardboard piece back in the cabinet. I found it was designed to fold up when covering the monitor to also cover the gap from the cardboard backdrop to the monitor. It fit perfectly into place, and it help block out light coming from back of the cab.
To alot of you here. this is a "so-what", but to me is was cool to make the discovery and watch it fall into place.
