Battlezone cabaret w/ V2000 / : Bright center spot in monitor
Wahoobies
Norfolk, United Kingdom (GB & NIR)
Hi all,
I have a battlezone cabaret. When I first start the game there is a bright spot in the center of the monitor. I've adjusted the brightness and contrast, and after a few minutes it looks exactly right on test pattern and in game.
Bright spots on vector screens make me concerned for further burn-in risk - any ideas where I should start looking?
Screen shot- you can see a bit of extra Z brightness on the copyright here, though I'm puzzled why it's mostly local to the center. When I adjust the brightness contrast it's *everywhere* when it's too high
A bad resistor or pot in a brightness circuit would lead to full brightness by memory
Got an ohmeter?
Careful with voltage (discharge with resistor needed etc) I'm guessing you already know that :)
Monitor turned off etc
