This shouldn't be a problem for arcade monitor. It might be a problem for some LCD panels and/or upconverters."The video syncs at 15.8k H and 56 V, so it's hard to dial in. The display comes up flipped on a standard horizontal screen."
Thank you pat9000,This shouldn't be a problem for arcade monitor. It might be a problem for some LCD panels and/or upconverters.
All of the 90's Midway games are 15.8khz x 54.7hz (Y-Unit, T-unit, Wolf, etc) and those games only might need a V-hold tweak if the monitor was previously running a 60hz game. They display just fine on any real arcade CRT monitor, and so should your Battle Cross.
Woo! Pat9000 for the win here.Thank you pat9000,
I will try it out on an arcade CTR monitor.
I always use an LCD Tv for repairs.
IIRC, my PVM didn't like it.This shouldn't be a problem for arcade monitor. It might be a problem for some LCD panels and/or upconverters.
When I get my machine running, I'll see if I have to do any video trickery to get to run. It really shouldn't be an issue for arcade monitors.
