Batman DE and Monopoly Issue
wmacmonagle
Donor 2012
Rosamond, California
Guys,
Though why not drop line here to see what is the main issue.
Batman DE:
I have not gone through why sound not working.
I just wanted to know where sound board is. Is it inside the backbox? If so.. which board? I am still pretty NOOB on it. I will go through maybe tonight or tomorrow.
Monopoly:
1. I ordered brand new Opto board and it still spitting the ball (ejecting and fire on it s own. It would empty the magazine and once ball reloaded in the passthrough. The ball will eject and fire again. I removed opto and it stopped.
Anybody has same experience and know how to fix. Drop line here. Thanks in advance!
For the monopoly, go into the service menu, tests, switch test. See which opto is flickering, or on constantly, or what. I suspect your opto emiting board may not be lining up with your recieving board, so the trough jam is always closed. That would make it think a ball is in the way, and try to eject it.
You can use a drinking straw to line up the opto leds to make make sure they are in line with each other. Just cut the straw to the distance between the board and make sure it is straight across when attaching the boards back into the game. If you have a manual it might have a picture of what I am talking about. Just remember to remove the straw.
pindork1 came by today and helped me and targeted the problem.. roll switch number 2 is the reason. it doesnt work . once it doenst work. system wil eject the ball.. once i hold roll switch 2 and it stopped ejecting but one ball a time.
i ordered some parts from pinball life and hopef ully get it by wed and will see the result from there..
thansk for the tips!!!
