astrodan88
Hi all,
I'm shopping a Banzai Run and I am stuck. The uppermost flipper on the upper playfield won't work. The other set of flippers on the upper playfield work fine. All other coils work as they should.
I've checked the things I feel confident checking and all these check out good:
All fuses
EOS switch
coil and diodes
wiring from coil to the interconnector board
The coil gets voltage and will fire when the lug is grounded.
My question is what should I do now. I'm not good with troubleshooting boards or reading schematics. I'm having trouble knowing which components I should test or what to do next.
Any help or tutelage would be greatly appreciated.
All fuses
EOS switch
coil and diodes
