Ballys Flipper Meltdown
jbk
Donor 4 years: 2011, 2013-2015
rivesville, West Virginia
I have a Ballys Hardbody pin that keeps having upperplayfield Rt flipper problems. When i got the machine the upper flipper on the right was frozen. The coil was shot and the flipper shaft was seized in the bushing. After replacing the coil and bushing every thing worked great. A friend was playing the machine the other day and everything quit. So today i began investigating and found a blown 43v solenoid fuse on the board. replaced with the mobile breaker and everything worked except the upper rt flipper. Found it frozed again. Took it apart and it is melted down on the inside (see pic). Replaced with a new AQ-25-500 coil and it pops the breaker again when engaged. The rt flipper has a single stack switch. Can someone give me the breakdown on the wiring lugs and which it which for the power stroke and hold. Any ideas???
does the upper flipper get its power from the EOS from the lower flipper? Does the coil you replaced have the diodes in place? Then does the upper flipper EOS work proplerly?
