I have my Aladdin's Castle it works fine. Just 1 problem. How do I set up for quarter play?? It does when i block the credit button with tape but how can I set it up and for matches?? any help would be welcome thanks.
It may just be set up (cheated if you will) for free play. You will have to look at the coin switches and make sure they are hooked up. Also take a look at the credit unit under the playfield or on the bottom tray. Match set up is in the back box, and is a plug that will say on/off.
Hope this helps.
