Bally World Cup Soccer DMD issues...
Yeah, ive run into this before. Ive already had to do some rework on a few of my other DMDC boards, and had to rebuild some traces. HV rebuild kits came in, so im going to get it done today. Wish I haad a diagram of the HV section, since ive never done this kind of rebuild before.
Pinwiki has what you need. A little further down from where I linked
Did you figure out your issue?
I just installed a LED ColorDMD in my World Cup '94 and it makes a world of difference!
I haven't fixed this yet. Been super busy moving games around and getting new projects into the shop. Was going to sit down today and rebuild the DMDC HV section. Ill update when i'm done.
Well, I did the rebuild. It was to say the least, a task. It took me 6 hours because of how damaged the traces and pads were. I didn't even know how bad the job was until I started removing things. 13 broken traces that needed rebuilding, and 9 non-existent pads. I salvaged some pads from another board, and used small component legs to make new traces. It looks like a sad sad patch work of crud. Finished it, put it in, and I have nothing on the DMD now.....
This pretty much broke my spirit. I spent a whole bunch of time going through everything I did, checking continuity between all of the traces I made, and they all check out. Only thing that doesn't make any sense, is that I'm getting some wildly inaccurate and off readings from Q10, Q7, and Q4 transistors. Brand new, they seem to already be dead, or shorted. I have no explanation for this. Maybe my test methods were wrong, idk. Im pretty burnt out on this.
Any advice?
Any advice?
For $110 + ship you can put this in and not ever worry about the fucker again
