Bally Surfers Free play option
ComettheStag
canal fulton, Ohio
I'm looking for a way to set my Bally surfers to free play so I can set it out for people to play at a convention. If anyone knows where the plug for this is, or a way to turn a coin return into credit up button without heavy modification that would be appreciated.
There won't be a plug.... but you could do a simple mod to the credit unit. This is the stepper unit in the backbox that has the reel showing the number of credits. It should have a switch or two that open when the unit is in the zero position... gently bend the switch so it's always closed, or jumper it with an alligator clip lead or something.
Thank you for the advice ill get a clip to put on it!
I saw something in the heads of Bally EMs which allowed free play. Or just set the credit unit up for max and flick the switch for the coin mech a bunch of times.
