OK, got home today and booted the game with only J3 and J4. Same issue happened, attract mode for a bit, then off. Turned it off then back on I went to touch the transistor to see if it was hot, when i touched it, the game turned off again, and the transistor felt warm. Not being able to repeat the turning off by touching the transistor, I detached the board, removed both transistors and put heat sink silicon on them, resoldered, reflowed some solder points on the plugs and put the board back in.
