Bally shooter rod parts
Grbgemen
Lincoln, Nebraska
Can anyone tell me where I can find the parts to rebuild a shooter rod assembly on a 1978 Bally Playboy?
Only part I have managed to find is the shooter rod itself. Well springs of course. What I need is the mounting plate on the outside of the cabinet and the molded plastic sleeve that is on the inside(shooter rod goes through).
I have a used sleeve but it has a Gottlieb part number on the back. I cant get my shooter rod to line up so it strikes the ball well.
EDIT: I suppose my current setup could be completely wrong. Maybe it uses a different sleeve setup?
Anyone?
Not sure about the plate, but I can tell you that the molded plastic sleeve is a standard coil sleeve. Can I send you one? Drop me an address on a PM and I can get you one.
Chris
Chris
Let me take a picture when I get home of what I got and we can go from there. Sounds to me like I have the wrong setup.
alright, sorry for the delay. here is picture of what I have.
The mounting plate looks as if someone tightened the nuts to tight at one point causing the studs to get pulled in a little. The studs are bent also.
EDIT: like i mentioned, that sleeve is a gottlieb part. cant be right. I did manage to find it on pbresource though.
