So I recently bought a revenge from mars. It is completly missing the left and right flipper assemblies. Can I use a WPC flipper assembly instead? Anyone else ever had this issue?
They might be the same identical assembly, I don't know either way on that, but I do know that the E.O.S. switches are opposite of normal flipper assemblies.
If your RFM uses a base plate with one of the four screw hole tabs missing, you may have to cut one off a new plate. No biggie, MB has a missing tab to clear other stuff.
