Bally Power Issue
dieseldogpi
Selden, New York
Another issue I am having with my Mr and Mrs Pacman is no General Illumination. I checked the rectifier board, I am getting 0 volts at fuse F5. This means that no power is coming in at all. Everything else has power, only the general illumination doesn't work. There isn't a connection issue, I checked the plug and the continuity is fine. So the question is, could this be the transformer?
Thanks!
Do you have 6.5 vAC at the yellow and yellow/black wires of J5? pins 1-4 are yellow and pins 7-8 are y/b.
Checking those I have 0 volts. Strange. Would that be the transformer? Really the only thing before that point. Except the plug before the transformer.
If you have 120 vAC going into the transformer , check the voltages on all the output lines going to the bridges. Is the AC present at them?
See, I am a little confused. It appears to me that the yellow and y/b wires come directly from the transformer and go straight the plug at J5. Attached are pics of what my board looks like, not my actual board (included only for reference, I can take actual pics later). Power hits the bridge before or after J5?
