Bally Lucky 7's Slot Machine Issues.
SkippyJoe777
Washington
I have a 1982 Bally slot machine (Although it deosn't have a name on it I think it is a Lucky 7's machine because the high end Jackpots are all triple seven payoffs). The MPU is an AS 2978-7. I am having a fault that all five payoff lines are blinking and WILL NOT reset for normal gameplay. The machine will not accept coins and the handle is locked in place. I have tried to reset the game at the board on the coin hopper and the fault just continues to blink even after the reset.
There is a blinking malfunction code of 54 which is not in the manual so I cannot determine what the problem is and/or how to fix it please give me some tips. This is my first slot so I am new to troubleshooting these. Help!!
The problem originally happened during payoffs and could be reset by pressing the reset button or by turning the machine off then back on. Now the problem is permanent and will not reset.
I just found out that Malfunction code 54 is for a "drop door switch". There are multiple door switches on this machine. Which one is it? Does it have anything to do with the coin drop selector solenoid?
