Bally Gold Rush, nickel machine
Troy56353
Hello,
I bought a Bally Gold Rush Nickel slot machine yesterday to restore for my wife. I have all the information off the placard, but I can't find any information anywhere on the web for it. I am trying to find a power supply for starters and then a coin mechanism. Both these parts are missing. I am looking for any schematics and parts lists specifically, but any information would be helpful. The information I have is:
Bally Manufacturing Corp
4/28/90 Stamped over Bally.
Serial #S900402096
Model #S63M36T-03
DMP-23-1993
On a sticker on the side:
Bally Gaming, Inc.
S63B36-00-1399
I would appreciate any information I can get.
Troy
I assume this is a pcb controlled slot and not electromechanical?
If so, can you provide pictures of the inside of the machine and the pcb?
Maybe a Proslot S5500? I have some Bally manuals and I might have a coin comparitor for that model.
You might also find some info on newlifegames.com.
Phil
There is a emblem on the front that says 5000Plus. Would that be like a generic case that could house different games depending on the boards installed and graphics? I took a few pictures you asked for. I hope this helps! The guy I bought it from said the "transformer" was missing and showed me the two connector ends in the base of the cabinet. I was under the impression that it was like a power supply in a PC, not a PCB. Any information and guidance is greatly appreciated!
Looks like you have a 5000+
It does look like the transformer and power supply are missing.
I assume you pulled the hopper out to expose the unattached plugs, or is that missing as well?
Try searching for 5000+ or 5000 plus information. Here is another thread from here:
My manuals are for the ProSlot 5500, so I don't think they would help you much.
But I will happily send them to you if you want. PM me an email address.
I would try newlifegames.com. They have a whole section for Bally reel slots:
Not sure if they have a manual section...
Phil
Phil
Hi Phil,
Yes, it is a 5000+. I finally got that figured out! The pictures I posted, I did have to pull the hopper out to take the pictures. Should I have a transformer and a power supply as in two different units? I researched a bit last night and figured out that the power supply should be an AS-2982-11. I was unable to find one for sale last night if I want a plug and play replacement, but I found that a lot of people have gone to a Meanwell RQ125D power supply and cut out the plug and wired it to the new power supply. I may have to try that if I can't find an actual AS-2982-11. I haven't looked at the machine a lot (it's cold in the garage right now) but I have noticed there is no power cord for it. I will have to look into that soon. I have figured out by looking at some other pictures of this type of unit, that I should have a CC-62 coin comparitor. I haven't had any luck trying to find that either, but the search has just started! Thank you for pointing me in the right direction!
Troy
Register an account at New Life Games for slots and poker machines. Great group over there.
www.newlifegames.com
Thanks,
Jason
I registered an account and spent my night researching! Got lots of good information, a couple of part numbers to start looking for and possibly some schematics to try and get this thing going with.
Thanks for the assist!
Troy
Hi Phil,
Troy
I think you need a transformer as well as a power supply. Try to look at a photo.
I wish I could help with the coin comparitor, but I only have CC-16s.
Good luck,
Phil
Good luck,
Phil
I've been looking for parts and can't find them anywhere so far. I did find this listing on Ebay, https://www.ebay.com/itm/2263803907...-b642-822e6a8cfb33|iid:1|vlpname:vlp_homepage
for a S5500 wiring harness, transformer, power supply and all the doo-dads. Do you think this would work in my 5000+?
Not sure. The harness is unlikely to work without at least modifications. Power supply you should check the specs and see if the outputs are similar.
Phil
