bally challenger ball bowler parts
Are you talking about the wire that the ball makes contact with which in turn activates a switch that lets the game know which pin should be lifted? If so, you can make your own. A method of making these wires is shown in a dvd that I would highly recommend if you are serious about restoring a ball bowler. It is called "Turkeys, Shots & Blows" EM ball bowler & shuffle alley repair/restoration(Top #8) and can be found here http://www.pinrepair.com/top. I also highly recommend the dvd on EM pins. Very good information. He covers nearly everything. Well worth the $$.
Motoman9 is right on. The video will suggest a thick (I believe the thickest you can buy)gage piano wire to make a new rollover switch. I believe the video also mentions that Tractor Supply Co. has a wire that works well.
I haven't had to fashion one yet, but it doesn't look too complicated. Good luck!
