Bally -35/-133 Help
Ripweade
Pennsylvania
I decided to check out my Baby Pac tonight to see if I can figure out a small problem I have.
The game boots fine, proper flashes on the MPU and Vidiot, and actually plays fine. The problem is that it's not seeing some of the DIPs. It seems that the first and third bank aren't being recognized, yet the second and fourth bank are. In the first bank, I have the side tunnels set to "liberal," which means they are supposed to be open when the game starts, yet they aren't. In bank three, I have the center arrow recall set to "on" but it doesn't recall the center arrows after the ball drains. For the second DIP, I have the "ball kicks out 3 times" set to "on" so if a player doesn't get any points, the ball will stay kicking out until they do, and that works fine.
I've checked out the schematic for the machine and I'll be darned if I can see where the DIPs are on the schematic! Does anyone know where on the schematics the DIPs are located? I'm trying to see what is common for DIP banks 1 and 3.
Bill
I'm looking at the PDF of the manual, and I see them on the last page, top/middle.
uMmvHIHU
Assuming you've already used your meter to verify the switch is physically working via a continuity check on the switches in question, you can track them back to the PIA (U10 I believe) from there.
