Ball Kick Out
Sirius
Ortonville, Michigan
Well, I took the plunge...again! I picked up a new pin over the weekend. Close encounters of the 3rd Kind. The machine is in decent condition. I bought it non working. The first thing I did was check the fuses and cleaned the connectors. That alone was a major improvement. Now the machine boots and plays. The only issue is the ball kick out does not work. When you lift the ball out of the hole it resets for the next ball as it should. So...bad solenoid? The reason I ask is because it's a CPU controlled solenoid.
