Ball getting lodged in Black Rose
caiphnaraya
Canada
Hello;
I recently bought a Black Rose, and have a general question that someone might be able to help me with. What's happening right now is there is one particular shot where a ramp opens up (Davey Jones Locker) and you shoot under it, thus dropping it down a hole and loading it into the cannon. Unfortunately, what's happening sometimes is it goes past the hole if it catches a bit of air, and gets lodged in the corner that resides behind the hole. No shaking is getting that ball loose, not that I would want that to be the solution, just .. it's stuck in there good is what I'm getting at, you're opening it up and prying it out. I was thinking about putting some foam tape on the corner where it is getting lodged, hoping that this would prevent the ball from sticking, instead making it bounce down and fall down the hole as it's supposed to.
http://www.homedepot.ca/webapp/wcs/...atchallpartial&Dx=mode+matchallpartial&s=true
The unfortunate part of this solution, if it's even plausible (I don't see why it wouldn't be) is with the ramp up, the tape would be slightly visible (it's dark in there, no GI or anything) if you knew what you were looking for, probably would only bother me though..
