Bagman sync question
TheDoomBalloon1
Permanently Banned
Donor 2017
California
Hi ok so i just found a Bagman PCB for my dedicated cabinet but I am attempting to hook it up to a JAMMA adaptor via a JAMMA converter(I never had an original harness)
My question is what sync does Bagman use, in my case a K4900? The pinout just says sync and doesnt specify type.
The JAMMA adaptor connects to the RGB G and NEG composite so Im wondering does Bagman need a positive sync signal also?
I can see the game working but I definately have a sync issue.
Also on the pinout it just has one speaker connection but JAMMA has 2 a positive and a negative?
Any help is helpful thx
Hooked it to my unicab with no sync-probs, so no idea. Do you have sync-output @ pin 17?
Try an Inverter like LS04. ;)
Speaker + is pin 18. Speaker - is GND.
JAMMA supports negative composite only.
Bagman is negative composite.
K9000 (and most other monitors of that era) support separate positive or negative sync, and composite syncs on H.
Bagman to JAMMA adapters are available on my website :)
Thx guys Hudson I pm,d you
On the pinout parts side R is listed as Table...never seen that before what is it?
