Bad tube in 6100?
JoeB1355
Seymour, Tennessee
So what happens if I hook up a good HV unit and deflection board to a bad 6100 tube?
The tube has a crack and I know there is no more vacuum in it.
will it destroy my flyback?
Basically want to see if the flyback in the HV unit and I don't have a good tube... So I would feel ok if it didn't blow up as a sign it might be good
I'm thinking this is a bad idea -- But I bet someone else has done it!
at least by accident!!
Don't do it.
Find another tube with the same pinout (if you can) and transfer the yoke...
Don't do it.
You and a couple other Klovers mentioned you once came across a TV 100° tube.
http://forums.arcade-museum.com/showthread.php?t=109572
But oddly neither of you mentioned the brand and model number of the TV, and you also never mentioned whether you tried it with a WG6100 chassis'.
Is all this top secret? A TV with a 100° tube would seem like a big deal these days.
Darren Harris
Staten Island, New York.
I know that I would be looking for a replacement for a 6100
I never found a tube, but others have mentioned finding one.
You can test the HV and chassis with a 90-degree tube, but it won't look right or long-term use...
Well, you did say, "I did find a TV once with a 100-degree tube, but it wasn't the same tube number....", so I thought that meant you came across a 100° degree tube.
Darren Harris
Darren Harris
I might have. Can't recall now...
Zenith model number S1989W3 has a 100 degree tube with the wrong neck connector (cr-23) tube didn't have a sticker. Damn.....have another tv to crack open to see what adapter it takes but it will be a while. Zenith TV has woodgrain sides with a LED channel display. I'll post photos later if I get around to taking them.
