Backbox lighting problem on Maverick
sundodger
Balla, Mayo, Ireland
i have only one circuit working on the general lighting of the backbox. I have checked that all connectors are good and i have no broken wires back to the power supply (i think)
THe circuit is the one with brown and brown and white wires.
It looks like i have no or very little voltage what would i check next.
Thanks.
Do you have a brown or crispy connector going to the driver board?
Should have said the fuses test good, sorry. the connectors looked ok but the light was bad will have another look once i get some daylight on the go.
I had the exact same problem with a Maverick. It's a loose connection on the PPB board. only half the back box lights worked. It's the plug on the upper left of the PPB board. you could resolder it, or try and wiggle it a little. mine fixed after unplugging and plugging it back in. Hope that helps
I had the same problem with my Jurassic Park. Like doodlesdaddy said, you most likely have a cold solder joint on the PPB. Pull the PPB and check connector J5 for cold joints, specifically pins 5 & 7.
as per Doodlesdaddy and Stangbat, cold solder on PPB. Reflowed all the joints to connectors and its perfect.
Thanks all.
