Back door for ms pacman?
Jarvis
Indiana
Does anyone have one they want to sell? If not i guess i can make one but can i see what it should look like? Measurements of where vents go? Anyone have the paint code for the blue color?
Thanks guys!!!
John
just measure it up and cut one out. gonna have to drill a hole for a lock and vents but all that is gonna be cheaper than buying one from somebody and the shipping charges.
or,
collect more cabs and steal one from it...
heh...
measure and cutting one to fit the hole is easy but i don't have a clue where the vents go or what they look like.
How aboutjust pic so i can at least make it look right even if i can't get dimensions.
Here you go.
I'm in the same boat. I have the wood to cut my own, but not the router to cut the lip at the bottom. I haven't thought about it in a while because you can't tell it's not there when the game is pushed against a wall. There are exact dimensions online:
http://www.retro.co.za/arcade/cabinet.html
Ms Pac Back
Depending on the saw that you are using to cut the MDF, you may not need a router. Sure it would make it easier, but if you are using a circular saw for example, change the blade depth to cut only slightly into the board, making as many passes as need to chisel out the remainder. Just a light sanding. If your using a table saw, use a dado blade for the same effect. Just watch out for kick back. Probably should use a feather board for this technique.
Jig saw and a drill is what I used to cut out the vent holes.
Hope that helps.
Love the info. Any have an idea of where i can get those wire screens? I know lowes and home depot sell some like that but is the close to the same?
