Babypac playfield rubber rings
OK, one more question and I think I have this thing beat. I need to order a cap kit but not sure what type monitor it is. I thought it was a GO7 but after looking at it I think its something else. I didnt see any apparent numbers on it. So what did these usually ship with? Figured I would ask before searching through the pics on bob roberts site.
Should be a G07 (FBO I think) 13" version of the G07. Pull it out, in order to identify it or post a pic.
That is a good question. Does the FBO have pretty much the same caps as the CBO? I'm hoping I won't have to get another cap kit soon since I have a bunch of CBOs sitting around.
My Baby Pac is the only 13" that I have, and I did it so long ago, I don't remember sorry.
Then again, now a days more than ten minutes ago is way back when for me.
one of my baby pacs has a WG K4800 in it- which is just the 13" version of a 4900, and the other is a g07-fbo.
fbo and cbo kits are similar, but not identical. Here's the difference i see looking at bob's inserts -
no c303 included in fbo.
c511 47u 250v instead of 47u 160v
c403 is 220u 25v instead of 100u 25v
c517 is 47u 25v instead of 100u 25v
thats the differences. But i would be 100% sure that it is a g07 before i ordered the caps.
i was figuring out the differences while you were typing that its a k4800.
here's the 4800 list -
1u50v c315/c351
2.2u50v c303
3.3u50v c308
10u160v c310/c311/c702
22u160v c506
47u25v c352/c354
47u160v c313/c507
330u25v c301
470u16v c205
1000u16v c201
1000u25v c701
I found the sticker on it, its a Wells 13K4806.
Both of my Baby Pacs have the 4800 in there. Got the cap kits from Bob Roberts as he carries the 4800 kit 'K4800 13" color' for $5.
That ball up top of the playfield is actually called a "captive ball" in pinball terms. Which explains why you can't get the ball past the posts. It works because the gap is large enough for the balls to touch each other (glad Phet isn't around). The drop target on the side that the ball is on will automatically drop out of your way so you can try to hit that ball. If you can send it to the other side, you get either energizer 1 or 4 depending which way you hit the ball.
-VJ
Yeah, 4800 in mine. I also got the cap kit from Bob. Baby Pac uses two standard sized balls (loop ball and main playfield ball).
Yeah the tilt ball is smaller on this. I lucked out and had a couple brand new balls from when I had a pin before. Its playable now but has a few minor issues I need to work on.
