You are using an out of date browser. It may not display this or other websites correctly. You should upgrade or use an alternative browser.
Museum of the Game® & International Arcade Museum® Forums
I have a babyPac here that has an issue. I am getting 10 flashes on the vidiot board but the MPU board is staying solid at power up. I checked the reset circuit and it seems to be ok. Pin 40 and pin 3 are both going high of U9 on power. It will go into the color chart and the communication test ok, and that's about it. Anyone can help it with this? Would be greatly appreciated.
I added a pic in case someone sees something obvious.
