Baby Pacman
Bodie
Wichita Falls, Texas
My Baby Pacman has two small glitches. First when you turn the game on the first sounds are a little distorted or missing some tones. Once the game has started the sound is perfect. The second problem is the monitor graphics very slightly shake on occasion, no warpage just a small movrment. Does anyone have any ideas what to check? Thanks in advance.
The startup sound always sounds a little wacky, thats normal. It kinda stutters, best way I can explain it.
The video problem could be caused by alot of different things. You can check the video connections from the vidiot board to the monitor. It could be cracked solder joints on the monitors RGBGS header. It may just be a hold pot that needs slight adjustment.
