Baby PacMan Pin/Vid Question
tomsav
New Jersey
I have a baby pacman pin/video game that is close to working.. Game powers up and playfield lights come on and go into attract mode. I can run the game through all the diagnostic modes, lamp, solenoid but the issue appears to be on the transmit and receive mode.. Attached is a picture.
All boards have been tested and are working fine, so Im thinking it's a communication issue between the boards (MPU and Vidot)..
Anyone have an idea what this issue may be and how I can fix it?
Thanks!!!!
Tom
Repin the data transmission connector between the MPU and vidiot board. Those number should match on both sides. Right now you have no numbers on the right side.
Reference here:
http://www.pinrepair.com/bally/babypac.htm
Here is the connector harness needed to make the communications test work between the MPU and Vidiot board:
VJ1 pin 3 - MPU J2 pin 9 #
VJ1 pin 4 - MPU J2 pin 8 #
VJ1 pin 5 - MPU J1 pin 5
VJ1 pin 6 - MPU J1 pin 6
VJ1 pin 7 - MPU J1 pin 28
VJ1 pin 8 - MPU J1 pin 27
VJ1 pin 9 - MPU J1 pin 26
VJ1 pin 10 - MPU J1 pin 25
VJ1 pin 11 - MPU J1 pin 23
VJ1 pin 12 - MPU J1 pin 22
VJ1 pin 13 - MPU J1 pin 21
VJ1 pin 14 - MPU J1 pin 20*
VJ1 pin 15 - MPU J1 pin 7
VJ1 pin 16 - MPU J2 pin 12
VJ1 pin 17 - MPU J2 pin 11
VJ1 pin 19 - MPU J2 pin 13
VJ1 pin 20 - MPU J2 pin 10
VJ1 pin 22 KEY
VJ1 pin 23 - MPU J2 pin 14
VJ1 pin 24 - MPU J2 pin 9 #
VJ1 pin 25 - MPU J2 pin 15
VJ1 pin 26 - MPU J2 pin 8 #
Thanks! Never repined before but the diagram you provided will really help.
Im thinking I would put new connectors and wires in, dont want to mess with the old stuff..
Would you know where I could purchase that?
Thanks again!
