Baby Pacman Drop Target Issue
webdoc90
Donor 2012, 2025
Simpsonville, South Carolina
Sometimes when the center drop target is down when I hit the ball hard at that same drop target the ball gets stuck under the play field plastic. I have 2 rubbers behind it. Any clues how I can remedy this?
Mike Martin
is there room to add another post behind the rubber rings? Go by the actual ring chart and make sure you are using the correct ring size for that area.
If it is still an issue, can you post a pic of that area? I've hit the ball into that area on mine and it never got stuck and always rebounded nicely. I'm wondering if the rubbers are not the right size. The right ones fit on pretty darn tight.
