Baby Pac help
TonyH
Donor 4 years: 2011, 2015-2017
Jeffersonville, Indiana
I just picked up a baby pac and was doing a good cleaning before I moved it into the game room. noticed there is no blue at all so I cranked up the blue on the monitor to see if one of the guns was out or to eliminate the game as the problem. Well the monitor turned blue as I feared. Checked the vidiot board adjusted the blue pot made no difference were the red,green pot completely changed the monitor colors. So with that I'm clueless I reseated the socketed chips no luck. The game plays great looks great just everything is red and green ish. For what its worth it does have a alltek mpu.
1) Check your wiring harness. Those #**#@)!!! pressure connectors they used on Baby Pacs are a nightmare, and lose contact easily. I had this exact same problem, and it took me a week of testing to figure out that my blue wire had lost its contact. Get a schematic and trace the blue wire from the monitor back, making sure it is conducting. Better yet, replace that connector with a real one.
2) If you've confirmed the harness is good, you may have an issue with the monitor. check the monitor forum for hints/advice
