B&W Cap kit question – Easy?
SchifWare
Shelton, Connecticut
Hi gang.
Trying to help out a guy in town that has a cocktail "Video Action" (pong clone) with monitor issues.
Symptoms: SOMETIMES on power-up, the screen is collapsed – and then after about 5 minutes will widen-out to almost be usable. It can be adjusted to take up the whole screen. Other times, it will remain collapsed, but will widen out after a little wiggle on the chassis.
My first thought – Cap-kit and re-flow the header pins (but I'm open for other ideas!)
Only problem is – I can't ID the monitor and thus don't know which of the 24 caps to replace. Also, there's a broken ceramic cap on the back of the PCB (lower-right of 'back' photo – as well as the close-up) that I'd like to replace since I thought it might be part of the 'wiggle' issue, but not sure of the value.
So – I'm turning to the pros!
1) Any idea which caps to replace? I included pics (let me know if you want me to email higher-res pics) AND a list of all the existing caps – with values – below.
-I was assuming I'd have to buy them individually, but if you know of an available cap-kit (or want to sell me one!), let me know. I'd rather not shotgun all 24 if I don't need to.
2) Any idea on the value of that ceramic cap?
Here are the values of the existing caps - as seen on their sides:
Position Farad Volt
cg16 .47 mf 315v
cf03 1 mf 25v
cd21 1 mfd 25wv
ch03 1 mfd 25wv
cg06 1 mfd 50wv
cf04 10 mf 16v
cf06 10 mfd 16wv
cc02 10 mfd 16wv
cg11 100 mfd 16wv
cd24 100 mfd 16wv
cd22 100 mfd 16wv
cf08 1000 mfd 6.3 wv
ce13 2.2 mf 160v
cf05 2.2 mf 16v
cj03 220 mf 16wv
cc11 220 mf 6.3wv
cj03 220 mfd 16wv
cd23 33 mfd 16wv
cg04 4.7 mfd 16wv
cf09 4.7 mfd 50wv
cf07 47 mfd 16wv
cj06 47 mfd 16wv
cd25 470 mf 25v
cg18 470 mfd 16wv
Many thanks, in advance!
-Chuck
Hi Ken and many thanks for the quick reply!
In looking at the manual for the TEC monitor, they do look similar, but unfortunately not spot on. Perhaps a variant? For example, the PCB is not mounted to a metal chassis shown in the manual.
In any case, I see that Bob Roberts has a cap-kit for a TEC TM-600/623.
Even though the reference numbers of the caps don't match and there are many more caps on the TEC monitor vs. the one I'm looking at - do you think that's my best shot?
Also - any idea on the value of that busted ceramic cap?
Thanks again!
-Chuck
The ceramic disc cap looks like it says, "202" which would be .002 uf @ probably 500 volts.
In the old black & white monitor days, there were really only 3 monitor makers out there making monitors that could be used in arcade games: Motorola, Wells-Gardner, and TEC. However, for a brief time there was a monitor actually made by Midway that showed up in some Sea Wolf games.
I don't recognize that monitor.....but I can say, it's not one of the Midway branded monitors.
Edward
MANY thanks for your replies!
-guess next stop is to find out what's in those kits as compared to my list.
Unless you have any other info, I'll give that a shot.
Thanks again!
-Chuck
