B+ K6100 High Voltage +240V!?!?!
Azurden
Donor 4 years: 2013-2016
Fairview, Pennsylvania
How high is to high??? I tested the B+ at the neck board and I am getting 240v and that is with the pot all the way down...
Some info about the build...
New LV2000 from Arcade Shop
New Fuses
New Caps
New Delection Rebuild - Ian
New HV Rebuild Kit (new HV pot as well - Ian
New Flyback
Pretty much reflowed the entire HV and deflection boards. Did not really reflow the neck board... I did not touch the HV cutoff pot...
Monitor works and all, but kinda worried with the voltage that high.
Thinking I am not taking the reading at the right location. One of the posts I saw said to take this reading where the RED wire attaches to the neck board... Does that sound correct? Still sifting thru posts... :)
Your best bet is to power everything off then get it up under the anode cup while positioning it so that you dont have to hold it at all. Then you can power up your game and dont have to worry about your hand slipping and knocking the anode cup loose accidentally.
