I've got a couple tubes I want to check with the B&K. My set up chart booklet is from 1999 and I can't find the two tube numbers in the booklet. I was wondering if someone knows the setup for these two tubes....
Tube #1 came from a 25" Wells-Gardner U2000 series. The only sticker on it is 088X0387-001.....This looks more like a Wells part number to me
Tube #2 is from a 39" Wells-Gardner K7601 dual resolution. The number on it is 088X0432-001.....I, also, assume this is a Wellls part number. All other stickers on both tubes are MIA. I'm guessing the heater voltage is probably 6 volts......but what's the G1 voltage? The standard 50....?
Thanks!
Edward
Thanks!
Edward
