butthead
OK I Bid high and win it. I get it in the mail, Looks Sweet, Like New Never Used. I had a Little Woodie going, I did good for a change. I hook her up following those there directions on a tube that takes out that there vertical deflection on the chassie from time to time. Everthing looks good and tests good. So I figure I would Blast her Good, So I set her to Rejuvenate and that there little light goes off. Yes the one that says Power. Switch to clean mode, no light. I call Bk no help, I start digging in all that there paperwork that done came with it and found me a damm Addendum,
It done there Says ,
This Model 480 crt tester has been specially wired for SEARS to Exclude the Clean balance and rejuvenate functions. Setting the Function to the Clean balance or Rejuvenate positions will automatically turn the instrutment off.
Which it does.
I am Pissed , Loose 600 Dollops in one week is almost a all time high for me Latley for two deals.
Well From a little Checking her out I did see two things.
Cut out R14 and Clipped a wire off of the transformer going to the switch.
Any input would be appricated.
Which it does.
