B&K 470 Owners
Slackmoe
Northern, South Dakota
I've read the instruction book several times and I just don't understand step 4. what cutoff voltage do I set it to? what about the one division part? anybody explain this to me.
thanks,
Andrew
The top scale is used for cutoff voltage. The first two numbers on this scale are 0 and .2. The cutoff voltage should be one division above where it defaults to, a division is the small markings, there should be three between the 0 and the .2. Usually I see the cutoff set to the first or second of these small divisions.
Ok Understand now, thanks alot Oryk
Andrew
