GoneMad
- Joined
- Mar 15, 2011
- Messages
- 1,347
- Reaction score
- 36
I recently purchased a BK 466 and a 467. 466 was working and the 467 not. I managed to get the 467 operational with the help of a few great members here. I wanted to get the 466 converted so it to could be functional with the CR series. No problem, with the instructions from Ken, I was able to build the adapter. Here's where it gets confusing. With the 466 hooked to a CR23 tube, I can
A) set htr voltage
B) set G1
C) set cutoff to each gun
After the above, it will only read emission on green gun, also, any further functions will only work on the green gun ie. remove shorts, rejuv, etc.
After doing some more research, I found this 8 year old post sort of explaining what was going on.
http://www.electronicspoint.com/b-and-k-466-adapter-advice-needed-t58425.html
I get the jist of what is gong on but could use a little light to get through this. I made the adapter as per page 63 of this manual. I know there are a few here that use a 466, just wonder how they have it working.
http://www.ionpool.net/arcade/100-CRT.pdf
A) set htr voltage
B) set G1
