Attn: Graphic Artists
DanoND
Bismarck, North Dakota
I need to recreate some side art (for my Race Drivin' Cockpit). I have a friend with a nice, new DSLR camera who's going to stop over this weekend and we're going to photograph it as best we can. It was recommended that I then vector-trace the art with something like Inkscape so it could be scaled to whatever size.
Since it only needs to be one size for every game out there, scaling seems like less of a priority. Are there other advantages to doing the vector tracing? What process do you guys use?
Man, he better have a MEGA pixel camera... I tried to get some decent pics of my Rampage CP and bezel, and my buddy is a professional photographer, and has a really nice 12MP DSLR, and when all was said and done, the resolution at actual size was only 150 or so... :(
I'd have to see the artwork to suggest a program to vectorize it.
Vector tracing is the way to go for recreating simple artwork. Art that has a lot of gradients and details (IE screen printed pinball backglasses) cannot be vector traced, unless of course you are insane. Think of the Pole Position cabinet art... that is a perfect candidate for vector tracing. Race Drivin' looks a little tricky, as there are some gradients and same details in the tire, but definitely doable.
Both Photoshop and Illustrator have vector tools. You can export any vector tracings you do in photoshop to illustrator and vice versa. It should be in an illustrator format (.ai or .eps) for printing.
In both applications, you use the pen tool to make the actual vector tracing. It is a point, click, and drag process that allows you to create complex shapes. The vector shapes you create are always editable, so it's not like using the paint brush that just throws pixels down on the canvas.
There is no advantage or disadvantage to using either software for making the vector shapes themselves. I prefer using photoshop for making the vector shapes, as the pen tool seems more accurate. However, illustrator should be used when applying the color to the shape, as it will store the applied color as part of the shape (Photoshop can do this too, but it's more refined in illustrator). I've been dying for them to just combine the damn things.
Once the vector is completed, it can be scaled to any size without any loss of quality (as they are computer generated algorithms that you basically create, as opposed to pixels, which get stretched and noticeable at the edges). Then it is a matter of making sure the vector is scaled to the right size so it can be printed on an adhesive.
Hope this helps, let me know if you have any more questions!
Brendan
All you need is a image big enough to draw over in illustrator. Once you have made the graphics vector you can scale it as large as you want.
Looking at the flames and wheel gradients they appear to be done using a vector program.
Also, it is important that the photo be taken directly from the side of the machine, otherwise what you trace will have the perspective issues due to the camera placement.
Brendan
Definetly use a tripod and make sure it's level, in all directions. You want the lens on the same plain as the machine.
You guys are great. I'm taking notes and we'll be sure to steady the camera and take the pictures straight-on.
I'm hoping as I make progress that there'll be a few more people interested in the side art to help reduce my costs.
The way I do this sort of work is to take several pics and the stitch them together in Photoshop.
The best way is to draw or tape a line on the floor parallel to the machine so you know the line is straight. Then put the camera on a tripod (or something solid) and take several pics 'straight on' with the legs of the tripod (or the box) on the edge of the line.. This will also save you having to resize pics to get them to fit together as you know they will all be the same.
For your project I would try the simple solution of stitching it together, tweak a few things, do the colours and then sharpen the shit out of it and see how it looks. You should get a pretty good result and easily good enough to print.
:D
