Museum of the Game® & International Arcade Museum® Forums
Up for sale... a variety of parts for Atari X-Y monitors. Maybe just what you need for your vector project.
All of this is sold as-is... condition noted for each item. Pictures to follow.
Wells-Gardner 6100
Deflection board #1 -- Complete minus one fuse. Has factory LV board. Looks all original and unmolested. I checked the four main transistors with a meter... they seemed okay (not shorted). The remaining fuses are all good. Naturally I'd still recommend new caps and a close look at other components before using it. $100. $85. SOLD.
Deflection board #2 -- This one is missing the main transistors/heat sinks, and some other parts. I'd call it a parts board... but it could be built up and used if someone had a mind to do so. $50. $40. SOLD.
Neck board #1 -- P315. Complete. All wiring appears unhacked. Neck connector looks good. This should be useable without a ton of effort. $75. $65. SOLD.
Neck board #2 -- P328. Pretty badly cracked... neck connector is gone. Parts donor. It does include a wiring harness that I believe attaches to the B+ connector... it looks good. $25. $20. SOLD.
H.V. cage -- Missing HV transformer and smaller transformer, focus assembly, several other components. The metal cage and the PCB itself are in decent condition. $75. $65. SOLD.
Yoke and purity rings -- Yoke tests good with a meter. A few of the white plastic clips in the center are broken off... should still be useable. Otherwise appears to be in nice condition. The rings look fine. $250. $225. $200. SOLD.
Other
Amplifone deflection board -- Complete. Dirty, like most of this stuff. Has a repair tag from who-knows-when suggesting it was repaired. I put a meter on the eight major transistors and they all seem okay (not shorted). Naturally I'd recommend going over it with a fine-toothed comb before actually using it. $250. $225. $200. $175. SOLD.
Electrohome G05-801 regulator board -- Complete. Dirty. Fuses not blown. The big transistors (Q100 and Q101) show a short between collector and emitter... I would assume they need to be replaced but I don't know for sure. $75. $60. $50. SOLD.
I also have a complete G05-802 monitor (with a spare deflection board for parts) and a complete Wells 19V2000 monitor... both rather project-y. I'm not interested in shipping those, but if someone wants to come pick them up (Louisville KY), I'm open to offers.
All prices plus shipping. I can ship wherever.
Any questions PM me. Thanks gang.
