Arcade1VA
Atari Tempest: Fully working and has the Tubes mod. This has one of the last brand new CRT tubes that Richardson Electronics had in stock. It has less than 5 hours of use and absolutely no burn at all. The cab shows its usual wear and tear, especially at the bottom and back at the tops (see pics). A new CPO and marquee overlay would really make it look good. I have a new roll of leather t-molding I will add, and if I can find it, the original manual. The spinner works good and has the usual brrrr to it. The on-off switch has been moved so it is accessible from the coin door instead of the back of the cabinet. Asking $1800. I have some wiggle room on this, but after the new tube and board mods, not much so no low-balls please.
This is located in Bethalto Illinois about 25 minutes from St Louis. Pickup is prefered, but I can ship if you make all the arrangements. It is in a basement and weighs a ton so bring some help as I just had surgery and cannot assist moving it. Please message with questions. Please only interested parties only. I do not have time for tire kickers or ghosters. Thanks for looking.
